Finishing Services
Chem film or Alodine™
Chromate Conversion Coating
Clear, Gold
Applications
Tools, hardware, electrical systems
Thickness
0.25-1.0 µm0.00001-0.00004 inches
Chromate conversion coating, more commonly known as chem film or by its brand name Alodine™, is a chemical coating that passivates and protects aluminum from corrosion. It is also used as a base layer before priming and painting parts. The standard most commonly specified in engineering applications is MIL-DTL-5541F, which refers specifically to coating of aluminum alloys.
This protective layer is much thinner than an anodizing layer, and while both are created by immersion of parts into a bath, Chem film or Alodine™ is a simple chemical coating and the process does not use electrical current.
Chem film or Alodine™ is a slightly cheaper process than anodizing, though it is more prone to scratches, wear, and cosmetic damage. The most common color of the coating is an iridescent greenish-gold, and thus it may also be used for cosmetic purposes. However, this color comes from hexavalent chromium, which is toxic, so for RoHS compliance needs, there are clear versions of the coating available as well.
Design considerations
  • Chem film or Alodine™ coatings offer a much greater electrical conductivity than bare aluminum
  • Media Blast parts before Chem film or Alodine™ to create a more consistent coating that hides small machine marks
Artificial Intelligence is no longer on the horizon for mechanical engineers—it’s already on our desktops, inside our CAD tools, and embedded in robotics on the factory floor. When I started working as a mechanical engineer 15 years ago, I didn’t think much about AI someday reshaping my job. Now the question has shifted from will […]
4-Axis CNC Machining: Capabilities, Applications, and Design Guidelines
4-axis CNC machining is a subtractive manufacturing process that moves a cutting tool and workpiece along four axes of motion—the standard X, Y, and Z linear axes, plus a fourth rotational axis (the A-axis) that rotates the workpiece around the X-axis. That additional degree of freedom is what separates 4-axis from conventional 3-axis machining. The […]
